Old 04-28-08, 10:34 AM   #1
Rear off center axle housing
Hey guys.
Just wondering if anyone can explain why would the Toyota Land Cruiser 100 series have the rear axle a little off center.
What would be the purpose and point of this?
page
pagemaster is offline   Reply With Quote
Old 04-28-08, 11:10 AM   #2
Village Idiot
Travis351's Avatar
TLCA# 16092
Check out this thread. http://forum.ih8mud.com/100-series-c...sale-slee.html
I think its position varies with lift and load.
Travis
1999 UZJ100, TJM T-3, OME 866 Heavy kit, Custom Sliders, Onboard Water & Mombasa Penthouse.
www.RealEstateBook.com
"Anyone will say anything under the influence of madness." Jesco White
Travis351 is offline   Reply With Quote
Old 04-28-08, 11:36 AM   #3
TLCA# 12205
Originally Posted by pagemaster View Post
Hey guys.
page
Lines up better with the T-case output. Ideally, both front and rear will be offset the same, as in an 80 Series, so you can pick a line over a boulder and not have to adjust direction when it goes under each axle. Also, it gives just a bit more clearance under the middle of the truck, though that is debatable.
Somewhat moot on the 100 due to the IFS.
Derek Lee
`63 Mercedes-Benz UNIMOG (404.115)
`64 Mercedes-Benz UNIMOG (404.114)
`81 Mercedes-Benz 300GD (460.333)
`90 Mercedes-Benz 500SL (R129)
`02 Saab 9-5 Aero
`04 Toyota Land Cruiser (UZJ100)
dclee is offline   Reply With Quote
Old 04-28-08, 11:37 AM   #4
TLCA# 12205
You're thinking of the axle shifting due to Panhard rod position as height increases. I think the original poster actually meant the offset diff housing. Though I could be wrong...
Derek Lee
`02 Saab 9-5 Aero
Old 04-28-08, 02:47 PM   #5
Trunk Monkey's Avatar
TLCA# 11251
As stated it's just the most direct line from the output on the t-case. It sucks tho since that means two different axle shafts.
Cory Fillmore
TLCA Western Individual Representative
99 UZJ
Trunk Monkey is offline   Reply With Quote
Old 04-29-08, 12:02 AM   #6
Ok. So the 100 is off centre and the 200 series is centred and my Toyota is centre in the rear.
What would be the benefit of the lining up with a most direct line? Is the centred rears not in a direct line?
PAge.
Old 04-29-08, 09:15 AM   #7
...pig searching...
hks3sgte's Avatar
PAge.
Almost all Land Cruisers have had the offset diff housings. The FJ25 had a centered rear housing, but up until the 200 series, they were offset.
Looking for an FJ55.
hks3sgte is offline   Reply With Quote
Old 04-29-08, 09:25 AM   #8
TLCA# 11251
Driveshaft no likey compund angles.
Cory Fillmore
99 UZJ
Old 04-29-08, 10:09 AM   #9
TLCA# 14008
I think the real reason for the offset diff is due to the design of the transfer case. In vehicles with centered rear diffs, the rear output shaft exits the transfer case inline with the output shaft of the transmission (centered). In Land Cruisers (thru the 100) the rear output shaft is offset to the side (in line with the front output shaft of the transfer). This requires an offset diff since d-shafts don't work well with compound angles.
1993 FZJ80, 180k, 3 diff locks, OME, ARB, Warn, Lightforce, Hankook MT, Part-time 4wd, Technitop.
Never owned anything but a Land Cruiser.
anderaa13 is offline   Reply With Quote
Old 04-29-08, 01:55 PM   #10
Jim_Chow's Avatar
Maybe the centered rear axle on the 200 has to do w/ the torsion diff t-case? Don't know what the big hype about the torsion diff is. We managed to get a nearly new (rental) V6 4runner stuck in deep tiretracks through soft dirt in 4WD when the diff lock was off by intentionally stopping the vehicle when the front tires went into the depression (someone else was driving). In this case, the torsion diff was useless (terrain was sandy board-flat florida). Locking the center diff got us out, so the torsion diff when unlocked didn't help at all.
'03 LX470: ART slotted & cryo'd rotors, Porterfield R4s pads, Stoptech stainless hoses, ARB sahara & Kaymar bars, HID's.
'86 4Runner: lots of mods incl rear electric locker, front truetrac, regeared, OME lift, ARB/Kaymar bars.
'01 Prelude SH: stock
'00 Honda CRV: stock
Jim_Chow is offline   Reply With Quote
Mortgages | Problem Mortgage | Mortgage | Debt Help | Loan
