Old 04-27-08, 08:19 AM   #1
Prodigy users: how did you get the wiring into the ashtray?
I did not want to drill the back of the ashtray housing blind to get the wiring through- I could not remove the trim piece that surrounds the ashtray slot and holds the cig lighter- the top clips came undone but not the bottom and I didn't want to break it.
Also, will the ashtray slide back in after you disconnect the prodigy? Does the clip on the wiring to the prodigy interfere with the ashtray fitting back in there?
I am considering carefully dremeling a hole at the back/top of the ashtray housing, big enough to fit that wire clip through, with it still in place in the dash.
rwheelz is offline   Reply With Quote
Old 04-27-08, 09:44 AM   #2
Mall-Cruiser
1loudLX's Avatar
TLCA# I NO HAZ K?
you have to remove, well at least pull up the trim around the shifter/cupholder to be able to remove that piece. Take the "butterfly" out of the cupholder and leave the door open. Gently pull up from either inside the walls of the cupholder or on the lip of the trim around the transfer case boot. its all presssure clips, so just pull straight up on that whole panel. Once you get that up and out of the way you can pull out that trim panel. If you want you can disconnect all the switches(heated seats/ECT/PWR/ect) and fully remove that center trim but its not needed.
2000 Lexus LX470 - K&N/SLP/HIDs/Clear Corners/LEDs/Nav/Sirius/Black LC 16"s/BFG AT 285s/Unity Spotlight/Black'd Trim
2005 Specialized FSR XC - CF HBar/XC Stem/Alias 143 Seat/Sidewinder Grips
Oo==L==oO
Need OEM Lexus LX470 Foglights? http://forum.ih8mud.com/sale-parts/2...s-98-02-a.html
Need some Michelin LTX M/S 275/70/16's? http://forum.ih8mud.com/sale-tires-w...-shipping.html
1loudLX is online now   Reply With Quote
Old 04-27-08, 09:58 AM   #3
offroadkid's Avatar
TLCA# 12427
I just orderred the Tekonsha P3 last week and will be doing an install when I get it. Keep us posted on your install, as I've been reading up on other peoples installs for ideas!
Joshua
1998 UZJ100 Imp. Jade Mica/Gray 295 Nitto TG's
“Some dream in color, I dream in 4 wheel drive."
My Wife's AVM story
www.findchristiewilson.com
offroadkid is offline   Reply With Quote
Old 04-27-08, 12:30 PM   #4
Thanks a lot! Good thing I didn't just yank it out like I was planning to, it likely costs a small fortune for that piece.
Old 04-28-08, 11:15 AM   #5
FATrabbit's Avatar
[N00b] What is prodigy? [/N00b]
'97 FZJ80 to '03 UZJ100 to (now) '05 UZJ100
Think I'm sticking with this one for awhile!
Now with: HIRs
OME 865s, OME t-bars, OME shocks, slee diff. drop
FATrabbit is offline   Reply With Quote
Old 04-28-08, 11:56 AM   #6
TXLX470's Avatar
You don't have to remove anything other than the ash tray...wires can be sent through the lett side of the ash tray...just put a bright light or a torch under the pedles and you could see the light from the ash tray hole...you might have to wiggle the wires little bit but u could do it. I just ran a antenna wire too through the same place to my cb radio.
There's hole above the pedles where u can run the wires through the firewall..
fatrabbit-progdgy is a brake controller for tailers/campers with electric brakes
98 LC 100, 100K MILES, MANIK BULL BAR , WARN DUAL BEAM FOG LIGHTS, SLEE STEP SLIDERS, NITTO 285'S,
TXLX470 is offline   Reply With Quote
Old 04-28-08, 12:35 PM   #7
LandCruisers4Life's Avatar
TLCA# 16244
I'm going to put a RAM style mount attached to the front of my ashtray and then put an Icom dual band HAM radio there
2004 UZJ100 "El Rinoceronte" - Gotta pay to play...
LandCruisers4Life is offline   Reply With Quote
Old 04-28-08, 12:45 PM   #8
Mall-Cruiser
1loudLX's Avatar
TLCA# I NO HAZ K?
why not use the blank space on the right of the dash cluster?
Oo==L==oO
Old 04-28-08, 01:24 PM   #9
TLCA# 16244
What blank space?
Old 04-28-08, 05:24 PM   #10
Getting a single wire or two through the ashtray is not the problem- the prodigy wiring has a plastic 4-pronged plug on the end of it, and I do not want the prodigy installed full time (I want to be able to unplug it and put the ashtray back in when I am not towing, which is most of the time).
SO, I need to mount the wiring in the ashtray space, such that the ashtray itself can slide back in with the prodigy wiring clip in place. I don't mind reaching in and pulling the wire out a few inches each time to use it, but this will require the plastic clip being run through a hole in the top of the ashtray space, if that makes sense.
OK, I can pull up that center console piece easy enough, but it seems it is still attached under the black piece I cannot remove (at the front). Here is a pic to show what I mean.
There are tabs on the black piece where the arrows are shown, and pulling up the center console piece it is also hung up here...
Old 04-28-08, 06:27 PM   #11
Mall-Cruiser
1loudLX's Avatar
TLCA# I NO HAZ K?
is your truck a 03+?
Oo==L==oO
Old 04-28-08, 07:00 PM   #12
Hot enough yet?
Campfire's Avatar
TLCA# 16416
I slid the entire ash tray out, and then mounted the bracket to the top of the ash tray bracket. That way if I ever remove it, the ash tray will slide right back in.
I used a piece of closed cell foam as an insulator on top to take up the space.
Jeff
1998 UZJ100, lifted, locked, 285's, TJM front, Slee rear, Warn HS9500, 7 pin mod, more stuff than needed. Oh yeah, a bent frame too.
1999 UZJ100, 285 BFG Muds, and all getting all that stuff above except the bending part.
Campfire is offline   Reply With Quote
Old 04-28-08, 07:17 PM   #13
Boston Mangler's Avatar
TLCA# 9060
What is this thing?
Baja Overland
www.bajaoverland.com
2006 XR650L
TLCA #9060
Own a Land Cruiser? Join TLCA Today @ www.tlca.org
Boston Mangler is offline   Reply With Quote
Old 04-28-08, 07:23 PM   #14
brake controller.
I need to install one this weekend. Yikes.
'04 100, Revo's OME lift/T bars, home made storage, Slee sliders (Sid), ARB, Warn 8k.
Kimberly Kamper (Kim)
More mountain bikes than I care to count!
gearguywb is offline   Reply With Quote
Old 04-28-08, 07:57 PM   #15
Yes it is an 03 LX470.
Old 04-28-08, 08:05 PM   #16
It really is very easy to install, at least on an 03... running the wire is not even difficult, if I could just get this ashtray surround piece out so I can dremel a hole and do a clean install!
Old 04-29-08, 04:12 AM   #17
what did you use for wiring the controller to the LX?
Old 04-29-08, 05:52 AM   #18
See this thread, my posts are down at the bottom... the 03 LX has a pre-wired plug for a brake controller, located under the dash. The Tundra harness makes the prodigy plug n play, with the exception of the ground wire which is simple enough.
http://forum.ih8mud.com/100-series-c...eries-tlc.html
Here is my thread on my complete tow package/setup:
http://forum.ih8mud.com/100-series-c...-research.html
I am using a 20' steel trailer to tow my s2000 or mr2 to the track. The trailer weighs ~ 2200 lbs (haven't actually weighed it yet), so with the s2000 we are looking at over 5000 lbs, which is why I went with the weight distribution hitch and anti-sway device. With the aftermarket hitch, we can tow up to 6500 lbs. I put my package together such that I could tow my GS400 across town if I absolutely needed to.
I have only towed the trailer home empty thus far, still need to get the weight dist/anti-sway installed, so I can test it with a car. The prodigy controller will lock up the wheels on the empty trailer using about 15% of it's power! I also got 14.4mpg on the way home and it was all 2-lane highway with many small towns
Old 04-30-08, 05:26 PM   #19
so nobody knows the proper way to take the interior apart in the 03?
Personal Injury Attorney Los Angeles | Final Fantasy Ringtones | Credit Counseling | Mortgage Calculator | Ringtones
