Just got some HIR's
I just trimmed them up, and put in the pass side bulbs, so once its dark out i can see the difference between the stocks bulbs and the HIR's
__________________ 2003 LC, DVD bypass, Dunlop SJ5 winter tires, Husky Liners, 113,000 miles Looking to get lifted this spring. 1998 LC, sold at 90,000 miles |
What is a HIR?
__________________ 2004 LC100, ARB Front, OME Med Shocks, Springs and Torsion Setup with Diff Drop kit, XM Radio and Revos!! 2004 Aprilia RSV Factory 1100cc Race bike.. Full Ohlins suspension, Arrow Ti full system exhaust, Power Commander Control Unit, Sticky Tires and a cool PowerRanger Leather Suit!!! |
Halogen InfarRed. they give 2/3 the performance of HID's at much cheaper price. they were devolped by GE now thosiba is producing the bulbs. you can get them at rallylights.com
They're used for off-highway applications (agriculture). They have a higher lumen rating yet draw the same 55w as a normal bulb. Your normal 9005/6 bulb has three tabs that lock it in place, the HIR's tabs are shaped slightly differently so you can't put them in. Few cuts with a dremel and you're good to go. I got mine off Ebay, $22/bulb. Cary's got an awesome write up on them in the 80 section FAQ.
__________________ Cory Fillmore TLCA Western Individual Representative 99 UZJ |
They may be used in off highway apps, but this is there history:
General Electric patented this new technology in 2000. Their intention was to create a bulb that emits about 3/4 as many lumins as an HID capsule at a fraction of the cost. The technology was licensed to Toshiba for automotive use. The technology involves a specially shaped quartz globe which has multiple layers of semi-reflective materials deposted on the inside surface of the bulb. The coating reflets a portion of the Infra red energy emited by the filament back to the filament causing it to glow hotter and produce more light, which escapes through the uncoated forward portion of the globe. Even though the filament runs hotter, the bulb produces about the same amount of heat as a stock bulb. Interestingly enough, the 9012 bulb can be used in a 9006 lamp with a simple modification with a Dremel tool or file. Due to federal regulations, we can not make this modification, but you, the end user, can. The material to remove is marked on each bulb. I also know they are now coming standard in some new cars, and trucks. __________________ 2003 LC, DVD bypass, Dunlop SJ5 winter tires, Husky Liners, 113,000 miles Looking to get lifted this spring. 1998 LC, sold at 90,000 miles |
don't hold your breath, I was NOT very impressed with mine. I'd say MAYBE 5-10% better, maybe...
IMHO, not worth the $ __________________ '03 100 75K- Color matched ARB Sahara & ARB Rear, Warn M12K, Hella FF4000 100w, REVO's, DVD Hack, Bilsteins, HIR, Hellroaring Dual Battery, DRL's off, Fogs work w/ High Beams '92 80- sold to brother-in-law!! '01 KTM EXC453 Dual sported, REKLUSE, Yoshi www.pacificflyfishers.com |
Really, now thats not what i want to hear. And you put those in your 100 or 80?
I've had mine in for a couple years and have been impressed. I would say it was closer to a 25% improvement for me. I did the high and low beams and got the bulbs from Daniel Stern.
__________________ 2000 UZJ100, OME 865, OME T-bars, Slee Diff Drop, Slee SliderSteps, TJM T3, PowerStop Cross Drilled & Slotted Rotors, 295 Terra Grapplers M101 Trailer - Sold 1993 Bontrager Race Lite MTB |
I had them in my 80 (with the Slee harness) and put them in my 100. Pulling the power straight from the battery was definitely an improvement, other than the connectors on the harness corroded quickly. In the 100 with it running through the alternator it's not as bright, but it's still an improvment. Just look at the numbers, normal is like 1100 lumens and the HIR is 1850.
If you want bright go with HID's. Wildyoats put them in his 80, no reason you couldn't put them in the 100. He did a write up in the 80 section. __________________ Cory Fillmore TLCA Western Individual Representative 99 UZJ |
#11 |
Just got back from a drive. I deffiently think the HIR's are worth the bucks. i see a lot of improvement. though i will say not as much as i did think. guess i will still be getting those driving lights also.
#12 |
IMHO a worthy mod.
__________________ 78 FJ55 - "Arnold" 78 FJ55 - "Wang" 89 FJ62 - "Ming" 07 UZJ100 - "Koto" TLCA #13476 |
#13 |
I think it's a worthy mad as well for the cost. However, I am still going to add some driving lights for certain situations.
#14 |
Look no further than Hella 4000's.
__________________ I'm married, I can't afford a signature line. |
#15 |
Brighter than cheapo Hyperwhites, or better than true HID?
#16 |
The cheapo bulbs don't put out more lumens, same as the Sylvania Star bulbs. It's just a different color of light. They're not as bright as true HID (depending on bulb temp of the HIDs).
Actress | Naruto Shippuden Episodes | Fast Loans | Vegas Hotel | Loans |
