Go Back   IH8MUD Forums > Toyota Tech Forums > 100-Series Cruisers
Old 11-19-07, 02:51 AM   #121
what the hell happened?
ats4x4dotcom's Avatar
we are running much firmer valving that the units you chose there for our bolt ons, initial tests are as good as expected, rear requires bump stop spacers, front allows 90mm of lift from standard with diff drop.
We have found this gives 350mm of ground clearance under the front to the new bash plates we make for the front.
Darren McRae 95 80 series 1FZ-FE with bits to come
http://forum.ih8mud.com/80-series-tech/207630-project-rooby-80-all-rounder-build.html
ats4x4dotcom is offline   Reply With Quote
Old 11-19-07, 09:03 AM   #122
calamaridog's Avatar
2000 UZJ100 - OME - sold Currently looking for the right FJ60
TLCA #14734
Calamaridog
calamaridog is offline   Reply With Quote
Old 11-20-07, 11:04 PM   #123
Tom B's Avatar
Is everything else kosher with running a 90mm lift once you get longer travel shocks: droop on the torsion bars, steering, alignment, CV angles, UCA's, etc? How are you addressing these issues? Is your diff drop taller than the standard Slee diff drop?
Tom B is offline   Reply With Quote
Old 11-21-07, 07:32 PM   #124
we use the slee diff drop, the vehicle copes with this lift as a maximum before the ball joint will top out, its the shock length that prevents the travel.
vBulletin® v3.7.3 ©2000 - 2009, Jelsoft Enterprises Ltd.
Car Loan | WesternUnion | Guitar Lessons | Credit Card | MPAA
