#61 | |
That's an idea...wonder how it would be with 2" in front and 2.5" in rear? __________________ Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM |
#62 | |
__________________ 98 LX470 85 BJ70 |
#63 | |
Yes...would like both flanges parallel to each other since I am running u-joints. FYI: I installed the OME 864's about 6-weeks ago...so the arse end is up a little higher now...it sits perfect all loaded with the trailer. Mine is weird...it feels just like a bad u-joint at times...then smooths out...then back to the vibe thing. I had our local drive line experts take a look at it...and they made sure I wouldn't take my rig there anymore .
#64 | |
Sorry, just thinking out loud... __________________ 2000 UZJ100 - OME - sold Currently looking for the right FJ60 TLCA #14734 Calamaridog
#65 |
Nice Dan.
I been researching this myself but leaning more toward Bilstein 7100 AK7112SB09 due to the short body availability that match N74L collapsed dimension but with 12" travel instead. This shock seem to be really popular on the 80 lately. With my closed to stock weight I could special order them with BE5-2740 stock valving to reduce guesswork. As for oil capacity I would not even worry unless you cycle your suspension at high speed a lot. In fact I liked ATS 4x4 bilstein due to its simplicity. The only drawback is cost for 4 unit because of the custom valving. If I use 7100 with BE5-2740 valving I could use stock front bilstein BE5-2739 and come out about $300 less. I am not interested with increased front travel due concerns with steering rack and upper ball joint. |
#66 | |
#67 | |
#68 | |
#69 |
Didn't do any high speed off-road today...but rocks and general travel through the hills...and they are much better than my OME's. More compliant and more controlled...and the suspension/truck felt like it was articulating better/more effectively.
#70 |
Off topic, but you mentioned a local drive shaft shop...I bet it's the same one I called 411 and asked for Tom Woods drive shafts from their lobby.
It amazes me how they will sell driveshafts for lifted vehicles and get mad at you when you go back in with questions/concerns...
__________________ "Passions Testify to Enthusiams for the Cause" F. Dostoevsky 1980 HJ45 Imported from Oz... 1994 80 locked, Supercharged, bored over 1.25mm long Ranger aux. fuel tank with Oz spec overhead gauge set. and other stuff... Adventure Trailer Chaser |
#71 | |
Exactly: Arrogant...expensive...and they don't know their sh*t! __________________ Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM |
#72 | |
what the hell happened?
PM
__________________ Darren McRae 95 80 series 1FZ-FE with bits to come http://forum.ih8mud.com/80-series-tech/207630-project-rooby-80-all-rounder-build.html |
#73 | |
#74 |
you need aprox 10% more valving for every 10 deg of angle you intoduce on the shock to 45 deg.
#75 | |
#76 | |
6.5" front 40/60 valving 10" rear 40/60 valving __________________ Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM |
#77 |
Need smores!
Looks great Dan, I'll come up and you can show me how good they work on one of those nice trails.
No rubbing problem with the front resevoir on the frame there? __________________ Jeff 1999 UZJ100, 285's, TJM front, Warn HS9500, four pinion front diff, rear locker, 7 Pin Mod, Airlift rear bags, OME 865 springs, Slee Offroard rear bumper, too much stuff. 2004 Lexus RX330 for the wife 1997 Subaru Outback 1994 Toyota X-Cab 4X4 1951 Willys CJ3A |
#78 |
No.
#79 |
Ok...Sam just learned, from one of his Taco customers, that Fox offers a nice easy to adjust click stop compression adjuster wheel that sits atop the reservoir [the customer found it on a Fox reseller's website...NOT from Fox directly (!)]. Apparently Fox doesn't list it...but if you know the part # it can be ordered. He is going to order just the adjustable compression valve 'cap/tops' and install them on my Fox shocks. I can't wait to feel how the different settings effect the tune.
I can certainly see why Fox wouldn't want to tell anyone about this cool and useful feature...jeez they might actually sell some .
#80 |
Spressomon,
help me to understand what the main benefits was over the Bilstein set up? I belive it is travel and valving correct? What did all this cost and and if I wanted to do it, what should I look out for? Thanks for the pics! |
#81 | |
I assume you are referring to the Bilstein 5100 or similar and not the 7100/9100 correct? The Fox shocks are completely tunable and rebuildable. Having said that they are a mono tube design. From what I gathered from Christo a twin tube shock design (OME, Bilstein non-7100/9100) maybe better for street use. However my desire is to focus the performance for more off-road. The Fox shocks as I have them set right now work very very well off-road. However they need additional dampening for ideal street use. I am hoping the easy to adjust manual clicker compression valve adjuster will allow me to firm it up for on-road use and when I am pulling the trailer. The other benefit from this shock design with the remote can is no fade when blasting over washboard! Not cheap...the shocks w/o the adjusters are $180-$200 each. Don't yet know how much the adjustable compression tops will add (will know within the next few days). Then custom upper front mounts (these are actually fairly easy to fab). And custom upper and lower rear mounts. Additonally...it appears some shock warehouses actually order Fox shocks as sort of a custom stocked item that you can't normally obtain directly from Fox...or at least Fox doesn't provide much assistance unless you have their part numbers. For instance Fox apparently offers a 2" non-coilover, remote res shock for a Jeep model that features a beefy post type upper mount like the stock LC...I just haven't had time to do the research to see if they offer this set-up in a 6.5" front travel and 10" rear travel (my shocks feature the more traditional eye mount for upper and lower mounts). As soon as the rear mounts are redone and I have the body lift installed I plan to provide all the details. __________________ Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM |
#82 | |
tlcwagons.org
fox, bil 7100 remote resv shocks are not emulsion shocks. That's worth it right there. so, you are getting an internal design that is best suited for fade-resistant performance (washboard, high suspension travel roads-like whoopdee's, etc) tuning the valving for your exact preferences and weight/terrain/handling. rebuildable The OME shocks are great for the price tho. I like the design and they are direct bolt-ons. |
#83 | |
Nope...not the Challenger shock...here's the link http://www.offroadwarehouse.com/prod...6/productID/95 __________________ Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM |
#84 |
The diameter of the top post on the 100 series is wider than other brands so I doubt that would help. I think you upgraded when you switched to the eye mount.
#85 | |
The Fox shocks Sam had with the stud upper mount looked pretty darn beefy but I don't know the actual diameter of the LC or these. However they're going on a Toyota Taco(?). Yep...I'm glad to be done with the post/stud type mount anyway. __________________ Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM |
