LinkBack (5) Thread Tools Display Modes
Old 08-15-07, 10:28 PM   #61
spressomon's Avatar
And these are the rears...
Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM
Old 08-15-07, 10:35 PM   #62
spressomon's Avatar
One more pic showing the front shock to upper inner control arm clearance. The smaller diameter shock housing allowed the control arm to droop slightly more than with the OME's.
Old 08-15-07, 10:38 PM   #63
24HOURSOFNEVADA's Avatar
TLCA# 14687
I like it alot...Very nice.
"Passions Testify to Enthusiams for the Cause" F. Dostoevsky
1980 HJ45 Imported from Oz...
1994 80 locked and things
Adventure Trailer Chaser
24HOURSOFNEVADA is offline   Reply With Quote
Old 08-15-07, 11:04 PM   #64
Snook's Avatar
TLCA# 9785
Cool!
How much lower is the new bracket to hold the lower rear shock absorber? Is the lower mounting somewhat vulerable to rocks?
The upper rear mounting bracket, how is it connected up there? weld or bolt?
Cheers,
Snook
2000 UZJ100
Nip/Tuck front ARB & rear 4x4Labs bumper w/ towing hooks - 8k Warn - Slee Slider - Drop diff - Slee T bar - 315 MTR - Slee HD Rear Spring - ARB Air Lockers - Regear 4.88 - Snorkel w/ GPS - ARB Refri - 1" spacers F & R - 3k W inverter - water heater shower system - '67 Custom Tailgated M416 trailer w/ Italian OverCamp
http://forum.ih8mud.com/100-series-c...100-snook.html
Video by Snook: http://www.tlcwagons.org/Norcal_Wago...os/Videos.html
Snook is offline   Reply With Quote
Old 08-15-07, 11:12 PM   #65
spressomon's Avatar
Originally Posted by Snook View Post
Cool!
Cheers,
Jay...hmmm I didn't measure how much the lower mount is from stock...I'll have to see if it is vulnerable or not...it looks like it will be OK...but time will answer that question.
The brackets were fabbed as bolt on...so I can reverse the path if necessary back to post style without cutting anything apart (based on how good the Foxes feel on the street I won't be going back to the OME's).
Old 08-15-07, 11:13 PM   #66
IH8MUD No-Lifer
hoser's Avatar
Did you or will you need to extend the shaft on the rear sway bar connecting rod?
98 LX470
85 BJ70
hoser is offline   Reply With Quote
Old 08-15-07, 11:23 PM   #67
spressomon's Avatar
I did that last year per the advice of ATS4x4 (Darren). I added 50mm...
The next thing, again per Darren's advice, will be to install the 10mm body lift to get the fenders just a bit more space from the stuffed tires (I'd like to install 12-14mm but don't know right now if that will be trouble for the fan shroud and/or steering column...waiting for Darren to chime in on that).
Old 08-16-07, 12:25 PM   #68
BHMCruiser's Avatar
That is an awesome rig. I can feel myself catching the 100 bug.
BHMCruiser is offline   Reply With Quote
Old 08-16-07, 08:25 PM   #69
bhmmapping's Avatar
TLCA# 18734
Blasphemy - you should go ask the 80's series forum for forgiveness before your headgasket explodes.
Alabama Chapter coming soon:
http://forum.ih8mud.com/al-bama-cruisers/
Matt
1992 FJ80 - OME 850/860, Bilsteins, ARB...
bhmmapping is offline   Reply With Quote
Old 08-17-07, 12:05 AM   #70
What you talkin bout?
rusty_tlc's Avatar
TLCA# 15069
Come over to the dark side, you know you want to.
Dan Johnson
Originally Posted by DSRTRDR View Post
maybe your life took a vacation without you and that's why you are going crazy........
Battle Born Cruisers
FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.)
And a pair of Pink Panties, now with a doohicky in the front.
Rust never sleeps.
rusty_tlc is offline   Reply With Quote
Old 08-20-07, 03:51 AM   #71
what the hell happened?
ats4x4dotcom's Avatar
Done
One thing you will need to do, as we do with fox shox install is to run the fox [or daystar] boots over the shafts, and fit the OME control arm mounted mudflaps they made for LTR's to protect the shock from stone damage in the rear.
Once you lift the top rear mounts, you can shorten the bottom mounts to suit, we used to machine a new mounting pin, plasma out a new hole in the front, with the pin going through the hole closer to the diff, weld in, then cut the shock mount off as short as we could up to that new pin we installed.
Darren McRae 95 80 series 1FZ-FE with bits to come
http://forum.ih8mud.com/80-series-tech/207630-project-rooby-80-all-rounder-build.html
ats4x4dotcom is offline   Reply With Quote
Old 08-20-07, 07:40 AM   #72
spressomon's Avatar
Thanks Darren...I appreciate your advice!!!
Old 08-20-07, 09:31 PM   #73
SWUtah's Avatar
Very nice work and build-up. One question based on the pictures, you ever wash your engine?
Mercedes SL550
LX470
SWUtah is online now   Reply With Quote
Old 08-20-07, 09:33 PM   #74
Rollin’ on 33s...
macneill's Avatar
TLCA# 12733
I don't clean mine either. Pisses 1LoudLX off for sure.
1981 FJ60 - Martha’s Vineyard - 210K, OME, BFG ATs, MAF header, hi-flo cat and Magnaflow, Surco Safari Rack, Rod Racks.
2002 UZJ100 - Brooklyn - 44K, OME 865, OME T-Bars, TJM T-15, TJM RB8, Slee Diff-Drop, Slee Tube Sliders, African Outback Roof Rack, Borla & SLP Exhaust, Warn, IPF, PIAA, Toyo Open Country ATs.
Gotham City Land Cruisers
Yankee Toys
Bay to Blue Ridge Cruisers
macneill is offline   Reply With Quote
Old 08-20-07, 09:38 PM   #75
spressomon's Avatar
It's clean now...we haven't had a drop of precipitation in over 80-days...
Old 08-20-07, 09:38 PM   #76
SWUtah's Avatar
I washed mine today, normally 2x's per year keeps it looking nice. I know I'm a sick bastard
Mercedes SL550
LX470
Old 08-21-07, 03:31 PM   #77
Snook's Avatar
TLCA# 9785
That's a nice sharp looking rig at Oysterfest I took last month.
Cheers,
Snook
2000 UZJ100
Old 08-21-07, 04:32 PM   #78
spressomon's Avatar
Cheers,
Thanks! I wish it looked as good now as when I first drove into the parking lot for Oysterfest .
Old 08-21-07, 10:27 PM   #79
That's a great rig. I'm waiting to see the outcome of the 10mm bodylift. I need some space for my 315 toyos and the lift might be it. Also waiting to hear on the dirt performance of the Fox suspension - I'm not too happy with the onroad performance of my OMEs.
I like the pin mod on the tire carrier - however do you not have a problem keeping it open on a slant?
I see your spade mounted on the high lift. Did you make some brackets for it or is their something that attaches to the high lift handle?
I really like your attention to detail! Gives me some inspiration. I guess I need to lear welding and get one!
Rohitash
call sign: KI6JDT, TLCA#: 17495
99 LC UZJ100, Slee slider steps, Dual Battery-Hell Roaring/Odessey, Toyo 35" Mud, TJM T3 front bumper, Superwinch ep9.0, OME Heavy lift, Slee Diff drop, Slee rear bumper with TC, IPF dual beam lights, Factory rear lockers, ARB front lockers and compressor.
rohitash is offline   Reply With Quote
Old 08-22-07, 07:58 AM   #80
spressomon's Avatar
[quote=rohitash;2468918]That's a great rig. I'm waiting to see the outcome of the 10mm bodylift. I need some space for my 315 toyos and the lift might be it. Also waiting to hear on the dirt performance of the Fox suspension - I'm not too happy with the onroad performance of my OMEs. Well...the firmer the tune for street...the firmer the tune for off-road AFAIK; however the Fox like the Bilstein 7100/9100(?) are tuneable. Maybe an electro-magnetic type of shock design would offer the best of both worlds?
I like the pin mod on the tire carrier - however do you not have a problem keeping it open on a slant? I only welded right hand (stock) hole in the bumper that held the pin/bumper in the closed position...leaving the hole for pin when the bumper is in the 'open' position.
I see your spade mounted on the high lift. Did you make some brackets for it or is their something that attaches to the high lift handle? I just welded a piece of round stock onto the Hi-Lift's base plate...simple, quick, cheap & effective.
I really like your attention to detail! Gives me some inspiration. I guess I need to lear welding and get one! Thank you! I went back & forth on the welder purchase for many, many years. Now that I have one I use it all the time...and as you know it's either not doing the project or hauling it off to a welder/machinist to complete...which didn't happen very often. My advice: Get the welder ASAP!
Dan
Old 08-22-07, 09:49 AM   #81
rusty_tlc's Avatar
TLCA# 15069
Mine too, we need to get them dirty again.
Dan Johnson
Rust never sleeps.
Old 08-22-07, 09:11 PM   #82
fj80psi's Avatar
My head gasket already exploded... So I can just say it. That is a kick ass 100 & It would be nice to have something like that next to my 80. Please report back on the Fox valving. I'm sure we all would apreciate some input from someone who has actually used them off road. Nice.
Everything is better with boost!
fj80psi is offline   Reply With Quote
Old 08-22-07, 10:26 PM   #83
Addicted to MUD Porn
locrwln1's Avatar
TLCA# 16879
x3
Jack
KE7NCK
1996 FZJ 80 (explorer)
2002 F350, PSD, 6SPD,4X4,CC, LWB (hauler)
1995 Mazda MX-6 (speedster)
locrwln1 is offline   Reply With Quote
Old 10-02-07, 05:47 PM   #84
Birdhunter's Avatar
That's a cool setup you have spressomon. You make such a strong case for learning to weld!
Regarding your dog kennels, I used to have two plastic kennels but I switched to two wire kennels instead. It makes it so you can see out the back and also I can check on how the dogs are doing on a long trip.
For anyone with their pups in the car, I definitely recommend having them confined. It keeps them in place on the bumpy trails, but more importantly, it keeps them confined if you have a wreck. I lost a dog after an accident (smaller vehicle) because all the glass broke and he decided to get the "heck" out of there. Unfortunately we were on a busy 12-lane highway. I miss mine sitting up front with me, but I always put them in the kennel now.
2000 White 100 Series - BFG A/Ts 295/75R16 desert pin striping /SUVcabinet.com drawer
Birdhunter is offline   Reply With Quote
Old 10-02-07, 10:35 PM   #85
spressomon's Avatar
Thank you Birdhunter. Just did the 12mm body lift last weekend. It's getting the rear shock mounts redone plus adding the Fox adjustable compression fittings to the remotes. Building a new pair of sliders...hopefully just in time for the Nevada Chukar opener (oh...its going to be a tough year up here for birds. DOW states just 1-chick per 100 birds this year )
