| View Poll Results: Will these rims look OK on a silver UZJ100? | |||
| Yes, subtle contrast with silver |
15 | 71.43% |
| No, stick with factory silver |
3 | 14.29% |
| No, Just paint them black |
3 | 14.29% |
| Voters: 21. You may not vote on this poll | |||
Hot enough yet?
Painted rims?
Trying to gauge if this is going to fly. I've been thinking of the colored rim look for a while but I'm really not into the completely black out look. So why not ask you fellow 100 Cruiserheads out there. I've been looking at dark grays, gray, etc. when I came across this color at the local ACE hardware. So?
Please be gentle ![]() __________________ Jeff "Not everything that counts can be counted, and not everything that's counted counts." - Albert Einstein 1998 UZJ100, lifted, locked, 285's, TJM front, Slee rear, Warn HS9500, 7 pin mod, more stuff than needed. |
IH8MUD No-Lifer
If you post a decent pic of your rig, I'm sure it can be photoshopped.
__________________ 98 LX470 85 BJ70 |
#3 | |
Hot enough yet?
Thanks hoser, but that would be too clean & easy. I'm out to paint the spare and put it on.... And here it is... It's a lot darker tone now that it's on the rim with the tire next to it. __________________ Jeff "Not everything that counts can be counted, and not everything that's counted counts." - Albert Einstein 1998 UZJ100, lifted, locked, 285's, TJM front, Slee rear, Warn HS9500, 7 pin mod, more stuff than needed. Last edited by Campfire; 05-22-07 at 08:05 PM. |
That color in the picture on the rig looks really good...what color, what type of paint?
__________________ 99 100 2.5 in. OME lift..863 rear, N74L's, NTG 295-75-16's, sliders, new front arb'd diff, 4wd again |
#6 | |
Looks good. But its hard to believe that's the same color on & off the rig! Would look even better sans the "hub caps" IMO. BTW your rig looks much better without the factory running boards. Are you going to get sliders? __________________ Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM |
You want to do what...?
why do you care what we think...?
__________________ '97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!) '03: 99K, the better half's... DD souped up DR650 |
Hot enough yet?
'Cause my Heep friends don't understand... It's a Cruiser Thing And to avoid chat, I'm painting one set of rims and leave the knobs on them. And then going for a set of Revo's on the 2002 silver rims __________________ Jeff "Not everything that counts can be counted, and not everything that's counted counts." - Albert Einstein 1998 UZJ100, lifted, locked, 285's, TJM front, Slee rear, Warn HS9500, 7 pin mod, more stuff than needed. Last edited by Campfire; 05-22-07 at 10:27 PM. Reason: trying to keep technical |
#10 |
I like the subtle contrast for your rig as it looks more off road. I would stick with the factory if you were going more for street/dirt combo look.
__________________ 06 LC, Toyo A/T 275/70/18, AHC "mini" lift and 1.5 inch spacers removed due to rubbing ![]() PM me if you need spacers! |
#11 |
Rollin’ on 33s...
Once you go black...
__________________ 1981 FJ60 - Martha’s Vineyard - 210K, OME, BFG ATs, MAF header, hi-flo cat and Magnaflow, Surco Safari Rack, Rod Racks. 2002 UZJ100 - Brooklyn - 44K, OME 865, OME T-Bars, TJM T-15, TJM RB8, Slee Diff-Drop, Slee Tube Sliders, African Outback Roof Rack, Borla & SLP Exhaust, Warn, IPF, PIAA, Toyo Open Country ATs. Gotham City Land Cruisers Yankee Toys Bay to Blue Ridge Cruisers |
#12 | ||
Hot enough yet?
It's not black, It's "Bronze" __________________ Jeff "Not everything that counts can be counted, and not everything that's counted counts." - Albert Einstein 1998 UZJ100, lifted, locked, 285's, TJM front, Slee rear, Warn HS9500, 7 pin mod, more stuff than needed. |
#13 |
[QUOTEDirect sunlight sure does lighten them up. And yes, I'm working on sliders Dan if I can get enough time to myself and some projects. Selling your yet?
[/quote] Not yet. Since they do the job building another set has dropped down on the list a couple notches. __________________ Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM |
#14 |
Jeff,
Couple questions - What did you clean them with? Why not powdercoating? As far as the look, it seems good, but how about a picture in direct sunlight... __________________ 2000 UZJ100 - OME - sold Currently looking for the right FJ60 TLCA #14734 Calamaridog
#15 | |
Hot enough yet?
And for the sunlight... and for Dan and the no cap thing... __________________ Jeff "Not everything that counts can be counted, and not everything that's counted counts." - Albert Einstein 1998 UZJ100, lifted, locked, 285's, TJM front, Slee rear, Warn HS9500, 7 pin mod, more stuff than needed. |
#16 |
just painted mine... "gun metal" wheel coat from duplicolor
#17 |
Bringing back an old thread from the dead. I finally painted my wheels last week. Had them mounted this morning. Whole process took a few hours. I just sanded the rims, primered a few times, and shot them with 3 coats of Dupli-Color Wheel Coating in graphite and 2 in clear. I like the results. Hopefully it will hold up.
__________________ 2000 UZJ100, OME 865, OME T-bars, Slee Diff Drop, Slee SliderSteps, TJM T3, PowerStop Cross Drilled & Slotted Rotors, 295 Terra Grapplers M101 Trailer - Sold 1993 Bontrager Race Lite MTB |
#18 |
Are you using enamel? It only lasts about 1.5 yrs in a high UV environment until it fades and turns chalky. The enamel takes about a month to cure, too. There's a water-based metal paint that lasts about 2.5 yrs, less curing time, but not as hard. Hard anodizing would probably hold up better.
__________________ '03 LX470: ART slotted & cryo'd rotors, Porterfield R4s pads, Stoptech stainless hoses, ARB sahara & Kaymar bars, HID's. '86 4Runner: lots of mods incl rear electric locker, front truetrac, regeared, OME lift, ARB/Kaymar bars. '01 Prelude SH: stock '00 Honda CRV: stock |
#19 |
Pint, that looks real sharp! I can't decide which way I'm going to go with my wheels, graphite like yours or straight black.
__________________ '01 UZJ100 Black '02 Camaro Z28, Black, 25K miles, *FOR SALE* |
#20 |
I vote for black also!
#21 |
I went round and round over the black versus graphite for 6 months! Finally I had to say, what the hell...it's only gonna cost me $50 in materials. I think black with my black truck and accessories would be a bit much for my taste. I wanted a little contrast.
#22 |
Looks good Pint.
__________________ Crain 1999 Land Cruiser 29k on the clock
#23 |
You did it right Pint! I like the graphite look. That's the color I was thinking about painting my new 18". But got lazy and cheap and left them facto silver. Good thing 'cuz they're already scratched
#24 |
I know they'll get scratched since I was cheap and used rattle cans. But that makes touch up easy as well!
#25 | |
Did the tire installers get the tires installed without scratching? __________________ Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM |
#26 |
Mors Ab Alto
I personally do not like the dark gray/black colored wheels. To me, they look like there is a ton of brake dust on them and need to be cleaned... IMO. Everone is different though, do what YOU like !!
__________________ 1989 FJ62-Freeborn Red-140,000 miles 2001 UZJ100-Champagne Pearl- 70,000 miles 2003 MBz CL55 AMG 1991 Range Rover |
