Old 01-15-08, 04:21 PM   #31
TXLX470's Avatar
In other words it's better change one and see the diffence than changing both at one time?????
98 LC 100, 100K MILES, MANIK BULL BAR , WARN DUAL BEAM FOG LIGHTS, SLEE STEP SLIDERS, NITTO 285'S,
TXLX470 is offline   Reply With Quote
Old 01-15-08, 07:04 PM   #32
spressomon's Avatar
There are two different camp thoughts on this one. However I should probably disconnect my batteries to reset the ECU per what I have read just to eliminate any doubt about what might be going on with the fuel efficiency part...
Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM
spressomon is online now   Reply With Quote
Old 01-15-08, 07:42 PM   #33
TXLX470's Avatar
Pls let us know the outcome after the ECU resetting..
Old 04-15-08, 04:54 PM   #34
Plastic Button Screws on the Splash Guard...
Originally Posted by Wellcraft19 View Post
I did this just (last?) weekend.
Error code P0155.
Remove the plastic "splash shield that cover the transmission (6 bolts, 12 mm). Follow the exhaust pipe up and you will see the O2 sensor clearly. I did post a picture, will try to find the post and link to it here.
You can easily get to it with properly sized crescent wrench, or a fixed wrench. I'll be running down to basement and provide the measurement in a little while.
If you cannot get it lose, start car and run fora short whle in order to heat up the exhaust. Might be easier getting to it then (note, I had not problems with either of the front ones).
When re-installing, add anti-seize, but MAKE SURE you keep the acual sensor clean!
Hi,
Wealth of information here. I am now ready to replace the O2 sensor. Quick question, how do you remove the 6 plastic bolts that hold that plastic splash guard? I tried to yank out the button but it only comes out a little, and it is stuck. I am afraid of breaking these little button plastic screws if I yank too hard. If I pull harder, would it pop out without breaking?
Thank you.
asong26 is offline   Reply With Quote
Old 05-01-08, 06:44 PM   #35
IH8MUD No-Lifer
hoser's Avatar
Yeah, you just yank the plastic plugs. One of them is different obviously cuz it's a nut instead. I just replaced two O2 sensors and there is a little less room to work with on my LX because of the AHC plumbing.
98 LX470
85 BJ70
hoser is offline   Reply With Quote
Old 09-01-08, 10:59 AM   #36
informationjunky's Avatar
TLCA# 6149
My drivers side went out about 8 months after the passenger...wish I would have knocked it out at the same time.
Georgia Cruisers
Upstate Cruisers
http://www.upstatecruisers.net/
TLCA 6149
86 FJ60 - first and RIP
95 FZJ 80 - second RIP
97 LX 450 - Current
locked, ARB, 850J's Front and 863's rear, slee drop blocks, 315's, and M12000, Devo sliders, Iron Pig rear bumper, skid on garge floor
98 LX 470 - wifes
informationjunky is offline   Reply With Quote
Old 09-01-08, 12:01 PM   #37
ginericLC's Avatar
TLCA# 7328
That makes me feel better about replacing both. I ended up buying a O2 sensor wrench at the local auto parts store. It is a $10 tool worth having.
Eric V. TLCA 7328
99 UZJ100 "T-REX Edition" under construction
FJ68 PROJECT aka LEGO(60 body, 80 Chassis/Running Gear)
74 FJ15 (that is about all that is left of it)
Lots of Parts FS http://forum.ih8mud.com/sale-parts/2...ml#post3693029
ADIDALC "real environmentalists don't pave roads" "dents are like tattoos with better stories"
www.WildWildWestArt.com
ginericLC is offline   Reply With Quote
Old 09-01-08, 12:49 PM   #38
TLCA# 6149
Its a tool I'd may a lot more than $10 for....glad there cheap. FYI the drivers side plug was easier to get to by pulling the skid plate loose.
Georgia Cruisers
Upstate Cruisers
TLCA 6149
97 LX 450 - Current
98 LX 470 - wifes
Old 09-07-08, 04:41 PM   #39
a monkey on the edge
Liam's Avatar
TLCA# 00012
does anyone have a picture or know where i can find Bank 1 sensor 1 (Code P0135). How hard is this one to change out and where is the best place to buy the sensor??
Originally Posted by Junk View Post
Wow. Def time to go home, celebrate with a beer and set your dick on fire.
Originally Posted by '74 UA FJ View Post
I am almost at my building when a girl I know pulls up beside me in her porsche. We shoot the shit for a second and she says "You really need a shirt on." Hahaha. I guess I am too much man for her.
Liam is offline   Reply With Quote
Old 09-07-08, 07:24 PM   #40
TLCA# 6149
Pretty much mirror location of Bank 2 sensor 1 shown in post 6. Pretty easy to change out with o2 socket (looks like crows foot with a flare nut opening)
Think they are a little over $100 at the dealer.
Georgia Cruisers
Upstate Cruisers
TLCA 6149
97 LX 450 - Current
98 LX 470 - wifes
Old 09-07-08, 07:36 PM   #41
Liam's Avatar
TLCA# 00012
$100? is that for the sensor or the tool?
Old 09-08-08, 04:47 AM   #42
TLCA# 6149
Sensor, tool is about $10
Georgia Cruisers
Upstate Cruisers
TLCA 6149
97 LX 450 - Current
98 LX 470 - wifes
Old 10-07-08, 12:43 PM   #43
O2 Replacement Easy
I just completed changing both front o2 sensors and it is pretty straight forward even for a non mechanic. One failed at 138k miles on my 2000 so I replace both front ones for about $190 in parts total. Thanks for the great instructions to all.
Two things I learned:
1.) There is a tab you need to push on the far end of the connecting plug which releases the plug. The tab is next to the bare wires away from the sensor and has little lines running across it. Just push it down and the plug unsnaps easily.
2.) Go to the Autozone or equivalent and use the free loan a tool program. They will lend you a O2 Wrench at no charge
I mail ordered from sparkplugs.com the o2 sensors and it worked well.
you need the socket for the passenger side and the other crows foot adapter for the driver side. Both are in the O2 wrench kit.
Thanks for the advice.....Bert
Big Bert is offline   Reply With Quote
Old 10-07-08, 04:56 PM   #44
ToyotaDon's Avatar
CruiserDan was only about $7 more than the Denso from oxygensensors.com for a '98 LC. Just ordered both fronts from him yesterday.
You don't want to mess with CDan.
http://forum.ih8mud.com/chit-chat-se...le-he-out.html
Donal
ToyotaDon is offline   Reply With Quote
Old 10-07-08, 07:01 PM   #45
wareagle's Avatar
FYI, I picked up a pair of DENSOs from ebay for $120 shipped. They worked fine. Replacement was veryb easy. Maybe a 45 minute job including R&R of skidplate.
Mark P - Franklin, TN
2000 LandCruiser UZJ100 - stock
1995 Trooper UX108 - lifted, locked, low'd
2001 Lexus GS430 - quicken'd
1996 Miata NA- slightly mod'd
http://www.cardomain.com/id/zutrooper
wareagle is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/100-series-cruisers/150958-replace-front-o2-sensor-procedure-very-easy-easy.html
Posted By For Type Date
Untitled document This thread Refback 02-16-08 11:06 AM
Loans | Remortgages | Web Directory | Car Accident Lawyer Los Angeles | Credit Cards
