Listed below are all the 100 series TSBs (technical service bulletins) listed on the US National Highway Transportation Safety Administration website as of August 2007 and as many foreign bulletins and recalls as I could find. This may not be all or even most of the bulletins issued by Toyota. If you are aware of any other bulletins let me know by PM and I'll add them.
Lexus LX470 TSBs are here -
LX470 TSB Thread (note that the Lexus TSBs are not identical and may cover common equipment even if Toyota did not issue a bulletin for the LC so I recommend checking both threads when dealing with a problem)
I will add a "MUD Notes:" line with any info that will be useful for board members that is not contained in the summary. For an example see the "Reverse to Park/Neutral Chatter" near the bottom of the 1998 list. This info should be from an authoritative source (i.e. the TSB) and could include a link to a forum thread focused on the TSB. If you have information and/or experience with a particular TSB and are willing to help other board members then I will list you as a PM contact if you want.
I found this Edmunds.com article on TSBs very informative and recommend that you read it.
You, Your Vehicle and the Technical Service Bulletin (TSB) (from Edmunds.com)
Hope you find this useful.
Australian Safety Recalls (12/15/2009)
Toyota - Land Cruiser and Lexus470 - Front Disc Brake Rotor Retaining Bolt
Date: 01/03/2007 Campaign Number: 7531A Recall Market Coverage: Australia
Toyota Motor Corporation Australia Limited
Product Model: Land Cruiser 78, 79, 100 & 105 Series & Lexus LX470 Target Number: 137,479
Model Years From: 1997 to 2005
Serial Range: Land Cruiser 10#. Model Code FZJ105, HZJ105, UZJ100, HDJ100. Lexus LX470. Model Code UZJ100. Production period 30 September 1997 through 5 December 2005.
Consequences: In the worse case of all bolts on one side displacing, continuous vehicle operation may result in brake pull.
Defect Details: When vehicle is operated under severe conditions with repetitive high "G" brake application forward and backward, excessive forces applied to the brake rotor may loosen the front bake rotor bolt/s. If vehicle operation continues in this condition, one or more bolts may loosen further (unwind) and eventually rattle. Owners of affected vehicles will be contacted individually by letter. -
Info at Product Recalls Australia
MUD Thread:
Front Rotor bolt recall/replacement
Land Cruiser 100 and Lexus LX470—Dash Board Wire Harness Interference with Pedal Support
PRA number: 2008/10050 Date created: 26th May 2008
Defect Details:On certain Land Cruiser 100 and Lexus LX470 vehicles, there is a possibility that the dash board wire harness may be abnormally twisted changing its intended routing in the vehicle allowing contact with the unprotected edge of the pedal support bracket. If the vehicle is continuously driven on corrugated roads in this condition, the wire harness will rub against the pedal support bracket damaging the wire insulation cover resulting in a short circuit and blown fuse.
Recalls.gov.au - Wire Harness
Toyota—Land Cruiser and Lexus—Front Disc Brake Rotor Retaining Bolt
PRA number: 2007/9087 Date created: 1st March 2007
Product description:Land Cruiser 7#. Model Code FZJ78, FZJ79, HZJ78, HZJ79, HDJ78, HDJ79. Land Cruiser 10#. Model Code FZJ105, HZJ105, UZJ100, HDJ100. Lexus LX470. Model Code UZJ100. Production period 30 September 1997 through 5 December 2005.
Defect Details: When vehicle is operated under severe conditions with repetitive high "G" brake application forward and backward, excessive forces applied to the brake rotor may loosen the front brake rotor bolt/s. If vehicle operation continues in this condition, one or more bolts may loosen further (unwind) and eventually rattle.
recalls.gov.au - Rotor Bolt
Toyota—Land Cruiser 100 Series - Bullbar Brackets
PRA number: 2006/8591 Date created: 27th June 2006
Product description: Bullbar Mounting adapter brackets manufactured between December 1997 and October 2004.
Defect Details: During heavy winching operations, there is a possibility that the welds on the bullbar adapter mounting brackets which attach the bullbar to the vehicle may fracture and in the worst case allow the bullbar to become detached from the vehicle.
recalls.gov.au - Bullbar Brackets
Toyota—Lexus LX470, Toyota LandCruiser 100-105 - Spare Tire Cable
PRA number: 2002/5421 Date created: 12th June 2002 Campaign Number: 2506F.
Product description: Lexus LX470, Toyota Land Cruiser 100, 105 models produced from 7 January 1998 to 2 September 2001 , and HiLux 4WD models produced from 29 July 1997 to 2 December 2001.
Defect Details: When the above models are regularly driven on rough corrugated roads at high speeds for long distances, the spare wheel winch wire cable may become frayed due to road transmitted vibration acting on the under body mounted spare wheel.
recalls.gov.au - Spare tire cable 1998 Toyota LC UZJ100 US Model – NHTSA TSB listings (12/15/2009)
ENGINE BANK 1 AND BANK 2 A/F AND 02 IDENTIFICATION
Service Bulletin : 03704 - SEP 03, 2004 NHTSA Item #: 10010021
EXHAUST BOOMING AT IDLE
Service Bulletin : 00304 - FEB 20, 2004 NHTSA Item #: 10006142
MUD Notes: Some 1998 – 2006 model year LC/LXs may exhibit exhaust booming after reaching operating temperature. To correct this there are various procedures for different vehicles. Installing a "Crossmember Damper Weight" (cast iron/rubber device on frame rail) or exhaust pipe dampers tuned to different frequencies. Credit to 100TD.
SPARE TIRE CARRIER OPERATION
Service Bulletin : PG00503 - AUG 19, 2003 NHTSA Item #: 10003563
CONTINUOUS ALARM NOISE FROM COMBINATION METER
Service Bulletin : EL00202 - FEB 22, 2002 NHTSA Item #: 629437
MUD Notes: Very loud warning buzzer from combination meter.
Buzzer scares wife and costs $1150.
Parking Brake Buzzer Serge troubleshoots Strange Sound and saves $1200
FRONT BRAKE VIBRATION
Service Bulletin : 757 - NOV 07, 2001 NHTSA Item #: 627469
Service Bulletin : BR0101 - NOV 02, 2001 NHTSA Item #: 627394
TOWING WIRE HARNESS CONVERTER REPLACEMENT
Service Bulletin : TC01030 - NOV 05, 2001 NHTSA Item #: 627356
SPECIAL SERVICE CAMPAIGN X03 TO REPLACE THE TRAILER TOWING WIRE HARNESS CONVERTER
Service Bulletin : TC99015 - JUN 18, 1999 NHTSA Item #: 608118
SHOULDER BELT ANCHOR TAPE SET
Service Bulletin : BO01901 - AUG 10, 2001 NHTSA Item #: 622728
MUD Notes: The solution is cleaning mentioned and then the application of "flourocarbon resin" tape to the Shoulder Anchor. Toyota part # 73205-48011 Tape Set, Shoulder Belt Anchor
MUD Thread:
Safety belts not retracting properly (FAQ)
TRANSFER CASE BUZZ NOISE
Service Bulletin : NV00101 - JAN 25, 2001 NHTSA Item #: 616661
Component: POWER TRAIN:AUTOMATIC TRANSMISSION:LEVER AND LINKAGE:COLUMN SHIFT
MUD Notes : To address TCase buzz at lowspeed/moderate acceleration and highspeed/light acceleration Toyota modified the "Highspeed Output Gear", "Shift lever and Linkage" and the "Center differential case" (ie.. the whole Tcase). The fix to the problem if you have it is to R&R the entire works. 7.4 hrs. Covered under 6yr/60k powertrain warranty if there is a specific customer complaint. New t-cases installed from VIN JT3HT05J#Y0114609. If you have questions PM NMuzj100 or Zimm with your email address.
SEAT HEATER REPLACEMENT PROCEDURE
Service Bulletin : BO01600 - APR 28, 2000 NHTSA Item #: 613502
Service Bulletin : BO01600 - MAR 31, 2000 NHTSA Item #: 610966
PRODUCTION CHANGE TO REDUCE THE WIND NOISE FROM THE UPPER REAR CORNER OF THE FRONT PASSENGER SIDE WINDOW
Service Bulletin : 001704 - APR 17, 2000 NHTSA Item #: 610085
MOON ROOF WIND THROB NOISE
Service Bulletin : NV00200 - JAN 14, 2000 NHTSA Item #: 610064
Service Bulletin : NV00100 - JAN 07, 2000 NHTSA Item #: 610063
IMPROVED BLOWER MOTOR DURABILITY
Service Bulletin : AC00499 - OCT 15, 1999 NHTSA Item #: 6088651
REAR BRAKE SQUEAL NOISE
Service Bulletin : BR00599 - SEP 24, 1999 NHTSA Item #: 607904
Component: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS
Summary: VEHICLES STARTING WITHIN VIN JT3HT05J*X0041300 MAY EXHIBIT REAR BRAKE SQUEAL NOISE.
REPAIR MANUAL CORRECTIONS
Service Bulletin : PG02099 - JUN 18, 1999 NHTSA Item #: 621990
Service Bulletin : PG01899 - MAY 14, 1999 NHTSA Item #: 621988
FRONT BRAKE PAD RATTLE NOISE
Service Bulletin : BR00399 - APR 16, 1999 NHTSA Item #: 605031
SCANTOOL IMMOBILIZER KEY CODE UTILITY
Service Bulletin : SS00199 - APR 09, 1999 NHTSA Item #: 605080
ADJUSTING PARKING BRAKE TO REDUCE RATTLE NOISE
Service Bulletin : BR00299 - APR 02, 1999 NHTSA Item #: 605038
MODIFIED REAR CUP HOLDER
Service Bulletin : BO00699 - MAR 26, 1999 NHTSA Item #: 604652
TOYOTA DINGHY TOWING GUIDE
Service Bulletin : AX00499 - MAR 19, 1999 NHTSA Item #: 604667
Component: EQUIPMENT:MECHANICAL:WRECKER AND WHEEL LIFT DEVICES
ABNORMAL NOISE FROM THE A/C EXPANSION VALVE
Service Bulletin : AC00199 - FEB 26, 1999 NHTSA Item #: 604643
Service Bulletin : 021699 - FEB 16, 1999 NHTSA Item #: 605168
Summary: ABNORMAL NOISE FROM THE A/C EXPANSION VALVE ON VEHICLES BUILT BETWEEN VINS JT3HT05J*X0024152 AND JT3HT05J*X0034757.
MUD Thread :
AC Groan or Growl
REPAIR MANUAL CORRECTIONS ON POWER TILT / TELESCOPIC STEERING COLUMN
Service Bulletin : 020599 - FEB 05, 1999 NHTSA Item #: 605173
WOOD APPLIQUE KIT CHANGE
Service Bulletin : AX00498 - DEC 04, 1998 NHTSA Item #: 603186
SQUEAKING AND RATTLING NOISES BEING HEARD FROM THE GLOVE BOX AREA
Service Bulletin : NV00698 - SEP 18, 1998 NHTSA Item #: 603847
WIND NOISE SERVICE TIPS
Service Bulletin : 980827 - AUG 27, 1998 NHTSA Item #: 602536
BUZZ OR RATTLE NOISE IN THE LOWER FRONT SUSPENSION
Service Bulletin : 980825 - AUG 25, 1998 NHTSA Item #: 602513
Service Bulletin : SU00498 - AUG 21, 1998 NHTSA Item #: 602171
REPAIR PROCEDURES TO REDUCE WIND WHISTLE OR TURBULENCE NOISE FROM THE SIDE MARKER LAMP
Service Bulletin : NV00498 - AUG 14, 1998 NHTSA Item #: 602182
WIND NOISE COMING FROM THE ROOF RACK
Service Bulletin : NV00398 - JUN 26, 1998 NHTSA Item #: 601606
ATTACHING A WIRE HARNESS BRACKET TO TRAILER HITCH CROSS TUBE WITH SELF-TAPPING SCREWS REQUIRES LUBRICANT
Service Bulletin : 980603980603 - JUN 03, 1998 NHTSA Item #: 601328
TRAILER WIRE HARNESS INSTALLATION NOTE
Service Bulletin : AX00298 - MAY 29, 1998 NHTSA Item #: 601604
AUTOMATIC TRANSMISSIONS PRODUCE A CHATTER NOISE WHEN SHIFTED OUT OT REVERSE INTO EITHER NEUTRAL OR PARK
Service Bulletin # : TC00198 - FEB 13, 1998 NHTSA Item #: 600349
MUD Notes: Transmission serial #s 97H*-00001 -> 97K-99999. 2.3hrs. Only covered under 6/60 powertrain warranty. Repair involves installing a new check ball into the valve body of the transmission. If you have questions on this TSB PM NMuzj100 with your email address. Thanks to CPJONES1231.
FUSE INSTALLATION DURING PDS - LAND CRUISER
Service Bulletin : PG00198 - JAN 30, 1998 NHTSA Item #: 600196
A343F 1-2 AND 3-4 SHIFT IMPROVEMENT
Service Bulletin # : 980101 - JAN 01, 1998 NHTSA Item #: 602535
