#31 |
The kit was $60 and they had one stateside.
__________________ 2000 UZJ100 - OME - sold Currently looking for the right FJ60 TLCA #14734 Calamaridog
#32 |
cdog: Did you get the steering rack bushings? FYI: I installed the new OEM PS side bushing...a 15-minute
job and it steers like it's supposed to again ![]() ![]() .
__________________ Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM |
#33 |
IH8MUD No-Lifer
Spresso, I don't suppose you have a picture comparing a new bushing to a worn bushing.
__________________ 98 LX470 85 BJ70 |
#34 | |
Nope. The difference between the new and old "grommet" wasn't real obvious...there appeared to be some wear on the bottom of the grommet...apparently from sliding back and forth. And the new grommet was black instead of faded black (the grommet is made from a medium hardness rubber like material). __________________ Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM |
#35 |
You just need a 3/8" flex ratchet and a 19mm socket to get the PS grommet cap off/on.
#36 |
IH8MUD No-Lifer
Thanks, I guess I'll jack my front end up and look for any play in the rack tomorrow. Or just spend $25 or whatever it costs and do it anyway. My 100 is almost at the 10 year/ 110k mark.
#37 | |
The play is apparent when you push/pull at 9:00 & 3:00 on one tire/wheel while both wheels are in the air...but I imagine you already know that . I had 1/2" side to side slop in mine. Answers why the darn thing had a wander on the highway .
#38 |
No, my fancy pants bushing is MIA.
#39 |
...Hopefully that`ll teach you not to circumvent your local dealership`s parts guy ![]()
__________________ 2000 UZJ100 OME 2" HD lift + "L" shocks, 305/70/16 Toyo MT`s , Slee diff drop, ARB front Bull-bar,Slee rear w/carrier, Custom exhaust, AO roof rack and drawer system, Various custom dents and scratches.... |
#40 |
rack on the LX has been leaking for years, its more wet(DS boot) than a leak, the fluid level has not hardly gone down(I have never had to add fluid) so...untill something really goes bad.....I aint touching it
#41 | |
Christo recently told me R&R of the hundy steering rack is THE worst job on this series! None of his mechanics EVER want to do one again. That sucks for us do it ourselfers .
#42 | |
#43 |
must refill power steering ever day
Hey Calamaridog can I get that kit from the dealer or if I have to order it from that site where is the number so I can place and order. I haved a 98 and the driver side boot is torn in half and I have to refill my steering fluid every day. are those bushings a fix to my problem or is it just replacing my boot cover
#44 |
You need to have the rack serviced or replaced. If anything is leaking it's not the mounting bushings.
#45 |
leaking steering fluid
Hey calamaridog when you rack is service exactly what does it intells. and how much an i looking at. Are you sure it not just the boot that has to bereplaced cause it is torn in half
#46 | |
You should consider getting a couple quotes. Perhaps 1 from Toyota and 1 from an independant shop. __________________ 2000 UZJ100 - OME - sold Currently looking for the right FJ60 TLCA #14734 Calamaridog
#47 | |
Thank to i4c4lo's advise and his extension tool, I was able to replaced the worn grommet with new one. Here are some photos for illustrations. Cheers, __________________ Snook 2000 UZJ100 Nip/Tuck front ARB & rear 4x4Labs bumper w/ towing hooks - 8k Warn - Slee Slider - Drop diff - Slee T bar - 315 MTR - Slee HD Rear Spring - ARB Air Lockers - Regear 4.88 - Snorkel w/ GPS - ARB Refri - 1" spacers F & R - 3k W inverter - water heater shower system - '67 Custom Tailgated M416 trailer w/ Italian OverCamp http://forum.ih8mud.com/100-series-c...100-snook.html Video by Snook: http://www.tlcwagons.org/Norcal_Wago...os/Videos.html Last edited by Snook; 09-05-08 at 11:07 PM. |
#48 | |
#49 |
#50 |
I don't know? I'll try and hunt him down next week when I'm in Vegas
#51 |
Snook,
Thanks for posting the pictures. I think it will help people understand the issue better. Isn't there a different set up for later models? __________________ 2000 UZJ100 - OME - sold Currently looking for the right FJ60 TLCA #14734 Calamaridog
#52 |
Anyone know if the rack is the same as the Tundra?
I helped a friend of mine install a poly kit onto his Tundra Rack about 6 months ago, said it made a world of difference. The kit is made by Total Chaos and "LOOKS" very similar and is only $28: ![]() Tundra Steering Rack Bushing Kit - Wheeler's Off-Road, Inc __________________ Baja Overland www.bajaoverland.com 2006 XR650L TLCA #9060 Own a Land Cruiser? Join TLCA Today @ www.tlca.org |
#53 | |
I rather use this poly kit but like you said is it same spec or not? How about asking Toyota part dept and ask if the steering rack grommet w/ same parts number is used for Tundra and Land Crusier or not? __________________ Snook 2000 UZJ100 Nip/Tuck front ARB & rear 4x4Labs bumper w/ towing hooks - 8k Warn - Slee Slider - Drop diff - Slee T bar - 315 MTR - Slee HD Rear Spring - ARB Air Lockers - Regear 4.88 - Snorkel w/ GPS - ARB Refri - 1" spacers F & R - 3k W inverter - water heater shower system - '67 Custom Tailgated M416 trailer w/ Italian OverCamp http://forum.ih8mud.com/100-series-c...100-snook.html Video by Snook: http://www.tlcwagons.org/Norcal_Wago...os/Videos.html |
#54 |
Good Idea!
#55 |
I ordered the Tundra kit to see if it fits. If not, I will just install it on my buddies Tundra. I'll let you know soon enough
#56 | |
