100-Series Cruisers Tech discussions for the 100-series, including the Lexus 470 models -- UZJ100.com
Old 02-06-07, 12:53 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Tire Patch Question
My wife ran over a nail in our 2004 LC. The good news is that the nail was right in the middle of the tread (not at or near side-wall). The bad news is that the nail went in at a sharp angle such that a regular old tire plug wouldn't work.
My mechanic first tried the tire plug. After the plug didn't work, he took the tire off the wheel and patched it from the inside. He 1) cleaned/ruffed up the area around the hole, 2) put some rubber cement looking stuff on it, 3) lit it on fire, 4) put on a patch and then 5) used a pizza-cutter looking thing (but dull) to ensure the patch made contact and rub out any bubbles). Unfortunately, when he re-mounted the tire, it still had a slow leak in it. Thus, he had to do the whole internal patch process again (he re-did steps 1-5). This time, it worked.
My mechanic assures me that the patch is safe. I'll keep an eye on the tire over the next couple of days to ensure that it's not losing air. Assuming it holds air, is the tire safe?
Note that our LC is used for on road street and highway use only (in Southern California, no snow).
Thanks!
ebod is offline   Reply With Quote
Old 02-06-07, 01:39 PM   #2 (permalink)
SWUtah's Avatar
Should be fine.
Black/Grey 2004 LX470
Black/Black CLS63 AMG
SWUtah is offline   Reply With Quote
Old 02-06-07, 01:53 PM   #3 (permalink)
Dain Bramaged Member
rusty_tlc's Avatar
I was told you should never run a plug as a permanente fix for a flat. They work great for a temporary fix but you should always get an internal patch done as soon as possiable.
Dan Johnson
What the large print giveth, the fine print taketh away.
Battle Born Cruisers
1975 FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.)
1998 pair of Pink Panties, now with a doohicky in the front.
1984 FJ60, Detroits F&R and a gawd awful spring lift.
Rust never sleeps.
rusty_tlc is offline   Reply With Quote
Old 02-06-07, 01:59 PM   #4 (permalink)
Dito sa bahay kubo ko
UltraFJ's Avatar
Why not move it to being a spare?
That makes the most sense to me.
UltraFJ is offline   Reply With Quote
Old 02-06-07, 02:18 PM   #5 (permalink)
SWUtah's Avatar
Damn I wish I would of thought of that
Old 02-06-07, 02:25 PM   #6 (permalink)
hoser's Avatar
Garage
These are the best patch/plugs I've come across. It is installed from the inside of the tire.
98 LX470
85 BJ70
hoser is offline   Reply With Quote
Old 02-06-07, 03:32 PM   #7 (permalink)
A tough subject, different laws in different states or countries!
In OZ IIRC, 18 years ago you used to be able to plug a tire from the outside with some glue and a cord/wick type plug. These went out and then a similar style of plug as Hoser's came in and had to be put in from the inside of the tyre. These went out and then you had to buff the tyre up on the inside and glue a patch on from the inside. Then a similar/modified Hosers style came in again I think and are around now. However there are lots of the cord type plugs being sold at all the shops, Kmart included, that poke a gluggy cord in from the outside. I am unsure if they are "legal" or allowed for temporary use(we all know that once they are in they stay in permanently).
The problem I believe is that the glue bond between the cord and the tyre flex st different rates and eventually fail. I have purchased a kit from ARB which comes from USA, and they state it is a permanent repair as the compound on the cord self vulcanizes to the tyre. It does not use glue. The product is "Safety Seal". I don't know if its leagl either but it works and the blurb on it sounds good(not that that ever means the product is good)
"Self Vulcanization
The first 100% self-vulcanizing rubber-fibre repair material
Non-Wicking
Wicking or drying out of a rubberized repair cord is caused by movement of the rubber sealant away from its retaining fibre. This happens when the sealant is non-vulcanized and will flow out under heat and pressure, leaving bare strings which leaks. This type of repair cord is classified as a tempory repair
SAFETY SEAL is a PERMANENT REPAIR since the sealant is vulcanizeable and will not flow under heat or pressure"
Make your own mind up about it.
http://www.safetyseal.com/store/offroad.htm
HDJ-100R TD 2003 Best mod, triple washer nozzle squirters Thanks to HOSER
100 TD is offline   Reply With Quote
Old 02-06-07, 04:29 PM   #8 (permalink)
SINCITY100's Avatar
SafetySeal is an excellent patch alternative, their plugs really do become "part of the tire" through vulcanization. Supposedly it is a "legal" repair (even on sidewalls) its so good in fact, that the CHP uses them on their fleet of vehicles.
I carry the full SafetySeal repair kit in my rig and although I have never needed to use it myself, It has been broken into several times for friends....Oh, and trust me... You can easily plug a BIG friggin` gaping hole in a tire with a just a handfull of plugs
2000 UZJ100 OME 2" HD lift + "L" shocks, 305/70/16 Toyo MT`s , Slee diff drop, ARB front Bull-bar,Slee rear w/carrier, Custom exhaust, AO roof rack and drawer system, Various custom dents and scratches....
SINCITY100 is offline   Reply With Quote
Old 02-06-07, 06:36 PM   #9 (permalink)
EdsCruisin's Avatar
Thinking waaaaaay back to the advent of radial tires as OEMs in the 70's, I recall that the internal patch was not as effective as the vulcanizing plug because of tire flex and steel strands poking through the patch. Too much movement in the softer sidewall radial tires to keep the patch attached. Plugs were the only way to go. On the other hand the patch technology has improved considerably too, so I would not be surprised if it works fine. I know my tire shop uses plugs for small holes and I have had no problems.
__________________________________________
'00 LC
'05 4Runner V8
A mind is like a parachute - It only functions when open
Stupid is a condition - Ignorance is a choice
EdsCruisin is offline   Reply With Quote
Old 02-06-07, 07:30 PM   #10 (permalink)
Mall Cruiser
1loudLX's Avatar
Garage
when i got my truck it had a nail in the right rear tire, that leaked ever so slowly. Anyways, plugged it with safety seal and it was fine till my tires wore down to nothingness.
At the local garage that was next to my house (just moved last week) all they ever repaired a hole with was the safety seal. If it couldnt be fixed with SS, then its time for a new tire.
2000 Lexus LX470 - No really, it's stock!
1loudLX is online now   Reply With Quote
Old 02-06-07, 08:54 PM   #11 (permalink)
rusty_tlc's Avatar
I carry the monkey grip repair kit, from their add:
"Permanent repair for all steel belted radial and bias-ply tires. Self vulcanizing. Cannot be cut by steel belts."
I had never considered the steel belts cutting a plug in half, sound pluasable though.
Dan Johnson
Rust never sleeps.
Old 02-07-07, 11:53 AM   #12 (permalink)
I think this is a bad idea. If you leave the tire on the truck, you'll know whether it's holding up or not. If you put it under the truck, it might continue to leak air and you could end up with a flat spare at a very inconvenient moment. Your spare doesn't have to be new tread, but it should be reliable -- most people don't check it regularly. Just my $.02.
ycookmd is offline   Reply With Quote
Old 02-07-07, 01:37 PM   #13 (permalink)
SWUtah's Avatar
He should know by now if it is leaking air.
LinkBack to this Thread: http://forum.ih8mud.com/100-series-cruisers/135837-tire-patch-question.html
Posted By For Type Date
The Daily Reckoning :: View topic - Most Americans Too Stupid To Do Simple 15 Minute Task This thread Refback 01-14-09 05:33 PM
