Fan/heater blower speed control from PreHeater Hi.
I'm having some trouble with my PreHeater installation, as it draws all the power off the battery.. I have found that the fan is running at full or nearly full speed...
Situation is, that a PWM relay sits on the preheater circuit, and is connected to a white wire with red dots on the standard Toy circuit. I believe the intention is to have the realy signal a pulse to regulate the speed of the fan blower, as just a simple voltage (DC) will run it at full speed....
So Q is, am I correct to understand things that way? And if so, would my PWM realy be suspect of fault, or are there other reasons possible?
My blower runs quite as it should on normal ignition, and I believe the fan at some earlier point in time was running at a lower speed, not discharging my battery every tiHe...
For now I have just put a switch in between the preheater and the realy, and thereby not activating the blower thus saving huge amounts of battery power...
Any thoughts appreciated..
Thanks i advance...
Regards...
Henrik |
