100-Series Cruisers Tech discussions for the 100-series, including the Lexus 470 models -- UZJ100.com
Old 12-29-06, 05:30 AM   #1 (permalink)
Dandon's Avatar
Destroyed my front brakes
As a heavenly punishment for what I wrote about unnecessarily changing disc rotors (http://forum.ih8mud.com/showpost.php...6&postcount=10), now my 100 is at the dealer with new front discs and the front calipers's parts spread on the mechanic's workbench.
A couple weeks ago I started to notice the typical worn pad noise, and planned to have them changed immediately. But then I had to make a trip and I put some 2000 km more on them. After that, it became a continuous and teeth-grinding screech. , and the braking feeling was downright scary.
The result is completely worn front discs (not to mention pads) and several rutted brake pistons. After trying everything including a night long soaked with penetrating oil, the mechanic has managed to extract all of the pistons, and only one of them is damaged by rust. So the parts bill will not be excessively high ( a piston costs 13 euro, and the whole caliper 400+), but I'm scared about the labor hours
I guess at least I have learned some lesson from this. And I hope it will not ruin all my bumper and winch plans, too.
I´ll post some pictures of the old rotors when I get the car back, so you can see what a rotor should never look like.
Regards,
Dandon - Madrid, Spain
'99 UZJ100 Euro Spec. - BFG AT 285/75/16 -CB-170.000 Km (106 kmi) - Scratches galore
"Roads? Where we’re going, we don’t need roads."
Dandon is offline   Reply With Quote
Old 12-29-06, 07:15 AM   #2 (permalink)
Dealer prices for brake parts in the US are: rotors=$103=Euro79, caliper=$364=Euro280, overhaul kit=$41=Euro32, upper piston=$18=Euro14, lower piston=$20=Euro15. If you shop on-line, some dealers give a 25% discount. http://www.trademotion.com/partlocat...99&catalogid=1
jp
2000 UZJ100@150Kmi, stock
jp213a is offline   Reply With Quote
Old 12-29-06, 07:35 AM   #3 (permalink)
Dandon's Avatar
Yes, I know I should have shopped around a little before taking the car to the dealer. I have also looked at www.euro4x4parts.com, which would be even cheaper. But i'm afraid it's too late now; I'll save this info for a next time.thanks for the info.
Regards,
Old 12-29-06, 10:25 AM   #4 (permalink)
DMX84's Avatar
With labor prices as high as they are, most shops will replace calipers with re-man units to keep cost down. I’m not a big fan of re-man units, but have used them in the past with mixed results.
Let us know how everything works out.
DMX
I may be vile and pernicious But you can't look away
I make you think I'm delicious With the stuff that I say
I am the best you can get Have you guessed me yet?
I am the slime oozin' out From your TV set"
I'm The Slime by Frank Zappa, 1973
98 Land Cruiser
01 Beta trials bike
71 GMC Shortwide truck
DMX84 is offline   Reply With Quote
Old 12-29-06, 12:15 PM   #5 (permalink)
jditom's Avatar
Well it sounds like you ran your pads to long but that does not explain your rusted pistons. Unless you did not change your brake fluid from time to time. Water gets into the system and will rust pistons.
Sorry dude
1996 TLC, Cooper D. STT 305/70/16, CDL, 7 PIN, OME steer & 850/863, Bilstein HD, IPA fog. Slee's front bumper, skid plate, CC bushings, SS brake lines x 7, light/aux harness & speedo gear. Warn XD 9000, Hanna sliders. 4X4labs rear bumper. OEM sub tank & overhead console. Projection headlamps, clear lenses, rear tail LED, George's inside LED's. MagnFlow exhaust (cat back). Eclipse Nav.
2005 GX470, KDSS, FJ wheels, Revo's 265-70-16, running boards,spoiler, roof rack off! HIDs.
jditom is offline   Reply With Quote
Old 12-29-06, 04:14 PM   #6 (permalink)
The rotors must be removed to repack the front wheel bearings so you might as well have that done too.
jp
Old 12-29-06, 10:33 PM   #7 (permalink)
Here is a story I'm sure some of you will appreciate; I heard my rear brake indicators sounding a little and had it checked at the stealer,
I mean dealer. they returned my truck saying I had about 4mm remaining on my rear pads, thought it was stange as I was certain I heard something... kept driving until the sound became metal to metal grinding coming back from a 45 minute road trip. Returned to the dealer right away only to be told that my rotors were shot!
I very calmly showed them my last service record only 6 days old stating the 4mm remaining; not to mention just two weeks prior I had them install the shim kit for all four wheels!!! The manager just looked at me and said " dont worry, we will take care of everything".
Needless to say I am sporting brand new rotors, pads, and shims, compliments of the dealer. Happy ending for a change!
99 LC100 (165K MILES), FULL OME LIFT 863's, L SHOCKS, SLEE DIFF. DROP, SLEE STEP SLIDERS, SAHARA BAR, REAR ARB JERRY CAN/TIRE CARRIER, WARN 9.5XP, IPF's, 285 BFG AT'S.
mmaakk is offline   Reply With Quote
Old 01-04-07, 08:21 AM   #8 (permalink)
Dandon's Avatar
Thanks for all your input. I just got my 100 back from the dealer, after parting with 550 euro (around 690 USD). I'll post details later, I have left the invoice in the car.
Regards,
Old 01-14-07, 02:50 PM   #9 (permalink)
Dandon's Avatar
Well, I took some pictures of the old parts. This is one disc, it was so thin the mechanic broke it while taking the caliper off:
A brake pad:
The rusted piston:
Regards,
Old 01-14-07, 03:03 PM   #10 (permalink)
Micah's Avatar
hey next time you feel that grinding again maby...
the rotor is telling you that you might want to check you pads.
89 62 257k miles, 4 inch BTB lift, 1 inch Body lift, snorkel, custom front, rear bumpers, M8000
"However, I consider my life worth nothing to me, if only I may finish the race and complete the task the Lord Jesus has given me - the task of testifying to the gospel of God's grace." Acts 20:24
Micah is offline   Reply With Quote
Old 01-15-07, 05:14 AM   #11 (permalink)
Dandon's Avatar
Yes, the worst thing is that I knew I had to change them urgently. Fortunately, I did not have to deal with an emergency braking situation. The rotors probably would have disintegrated.
Regards,
Old 01-15-07, 10:27 AM   #12 (permalink)
Mall Cruiser
1loudLX's Avatar
Garage
at least I know what will happen now if i neglect to change my brakes.
1loudLX is offline   Reply With Quote
Old 01-15-07, 09:41 PM   #13 (permalink)
Just a warning to anyone who lets their brake pads go till the last mm thickness; the inner pads sometimes wear faster than the outside pads and it looks like all is ok through a quick visual. if your wear indicators are working properly you might catch it in time, if not
that distinctive metal to metal sound will surely get your attention.
of coarse, too late by then!
