Old 12-27-06, 12:20 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
NMuzj100's Avatar
Thottle Position Sensor/Accelerator Pedal Position Sensor problems
A Readers Digest on the TPS/APPS issues with links to the relevant threads. Send me any feedback/corrections/recommendations in a PM and I'll make changes.
TPS = Throttle Position Sensor
APPS = Accelerator Pedal Position Sensor
TB = Throttle body
Known issue 1998-1999
Sudden lack of accelerator response, “Limp Mode” (e.i. approximately 25% power), power available only when "floored"
May be associated with cold weather
CEL with codes
  • P0120 – TPS (98 FSM DI-38)
  • P0121 – TPS (98 FSM DI-44)
  • P1120 – APPS (98 FSM DI-104)
  • P1121 – APPS (98 FSM DI-104)
In TRAC equipped vehicles may set "VSC/TRAC" and "VSC OFF" lights as well.
If engine is shut off the truck may start with no sign of the problem and drive normally.
If the truck drives without problem the CEL may go out after a number of miles.
Pulling the EFI fuse from the fuse block for a few minutes will reset the CEL.
Repeated occurrences are usually solved by the replacement of the APPS (~$270) and sometimes the TPS. (~$70). Dealers often recommend replacement of the entire TB (~$1050).
The TB assembly from a 01-02 Tundra is the same part number and maybe easier to locate used.
R&R covered in the FSM SF-35.
Possible causes
  • defective part design (APPS part# has been "updated" 4x)
  • dirty throttle body
  • dirty throttle body possibly caused by EGR system
  • bad electrical connections
During replacement it is recommended that you clean the throttle body.(FAQ - throttle body cleaning)
Consider replacing the starter contacts at the same time if you need to do them. You will have done some of the work needed to access the starter.
Some threads ....
Val678 – TPS/APPS problems in a 99 LX
DMX84 – TPS problems
EdsCruisin – APS problem possibly caused by build-up in the throttle body
EdsCruisin – APS problem and even i4c4lo suffers from TPS
TPS problem poll by rph1974 - Post up! Even you lurkers with no problems.
HI Trek - CEL code 'P1126' --> Magnetic clutch
PSDarmoured – TPS failure in a bad spot
calimaridog troubleshoots an electrical problem related to a starter job – fj55-100 explains dirty throttle body problems in post #11
Dealer wants to replace entire thottle body at $1400 - onesprung60 explains why and provides a "migrating grease" theory of TPS problems
Maingear troubleshoots a P1128 Throttle Control Motor Malfunction and Chad in Bangkok may be experiencing a TPS problem
TPS limp mode, now OK, fix or not? - Landpimp (Part # details from SinCity100)
loss of power? - AFRIKANZ struggles with "twit" dealers and a non-OBD2 EC market 100
yotor no motor
1998 UZJ100 146K 285/75R16 Revo 2s, D-light mod
1999 Toyota Camry - So Boring
NMuzj100 is offline   Reply With Quote
Old 01-23-08, 12:21 PM   #2 (permalink)
Rookie
Thanks for all the info!
James A. Iddings
2000 UZJ100 "TLC Enterprise" 120k
1986 4Runner "Galileo" 22re 265/65/17 210k
To Boldly-Go where no 100 has gone before........
ammodragon is offline   Reply With Quote
Old 01-23-08, 12:30 PM   #3 (permalink)
You want to do what...?
e9999's Avatar
nice, thanks for taking the time.
have put it in faq
: '97: 90K, 3xlock, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!). Custom HD roo bar for sale!
: '03: 115K
DDs: Accord, Prius
: souped-up DR650
LinkBack to this Thread: http://forum.ih8mud.com/100-series-cruisers/127474-tps-apps-problems.html
Posted By For Type Date
Untitled document This thread Refback 03-14-08 04:09 AM
